Sean avatar image
Sean asked
Incorrect voltage displayed - Blue Smart Charger IP22 24V 16A
screenshot-20220519-113322.jpgscreenshot-20220519-113315.jpgInteresting fault...
Output voltage is measuring correctly (with a multimeter) and charges with appropriate current, however the app indicates it's charging at around 18V and 16A (which I know to be false). Latest firmware and app. I've tried cycling power, reinstalling app, reducing output current to 8A, Power supply mode at both amp settings, all of the modes - nothing changes the displayed output voltage from around 18V. Any solutions?
voltagebluesmart ip22fault
@Sean
If it is that far off and there is nothing wrong with the multi meter, then I would honestly take it back.
Sean avatar image Sean Alexandra ♦ commented ·
That's what I figures. Thanks
Paul B avatar image
Paul B answered ·
what alexandra writes maybe correct
But You dont tell us what the voltage is that your volt meter is displaying ( is it higher or lower than whats indicated) you do say its wrong but by how much - if it is charging at 16 amps then the batteries maybe overly flat
Blue Smart IP22 Product Page
Blue Smart IP22 230v datasheet
Blue Smart IP22 120v datasheet
Blue Smart 230V online manual
Blue Smart 120v manual download
Victron Connect online manual
Did You Know? - use the blue smart as a power supply (video link)
History and Settings for Blue Smart Chargers in Victron Connect (video link)
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
