Fra avatar image
Fra asked
Low frequency pure sine inverter??
Halló, I noticed that some inverter manufacturers produce a type of pure sine inverter "low frequency".
They are expensive and extremely heavy! 30 kg for 2000 watts! screenshot-20220518-112443.jpg
Waht is the use of these types inverters?
Make victron something similar?
Thank you.
Phoenix Inverter
klim8skeptic avatar image
klim8skeptic answered ·
Difference between LF and HF inverters.
Link^^.
Alexandra avatar image
Alexandra answered ·
@FRA
Yes Victron makes something similar.
They have the 2000w inverters for all voltage bases 12v/24v/48v.
Low frequency usually suggests there are heavy transformers in the inverter, but there is an argument as to whether that makes them "low frequency". The Victrons use a torroid type transformer, I would say better than the square type.
The toroid type inverters handle higher surge loads and overloads better. And have quite a few other advantages. The main one being they are a bit more robust.
Fra avatar image
Fra answered ·
Thanks you I now these victronenergy inverter. Actually I have a victronenergy inverter in my system. And it work perfectly 12 hours per day from 4 years!!
I was just wondering why some companies produce both high frequency transformer inverters and heavy low frequency inverters.
I was wondering what was the advantage of choosing a low frequency inverter with the same power, voltage and waveform.
Because you are buying a very heavier product more to have the same rated performance.
My. Victronenergy phoenix is perfect. Just asks me why a company offers for inverters of equal power, both high frequency and low frequency models. I guess that's a reason to choose one over the other?
