kurt-krueger avatar image
kurt-krueger asked
Can you plug a 12/500 Phoenix Inverter into a car power port?
My 2016 Lincoln MKX has 20A fuses on the 12v power plugs. Power plugs (cigarette lighters) typically can handle 15A (12V x 15A) about 180W. Theoretically, if I don't plug more than say 125W load into the inverter it should work at least I was hoping it would. I have both an in car (less than 125W) and direct to battery (full 500W use cases).
Unfortunately, when I tried this my 20A fuse popped with out anything plugged in the inverter.
Is there any way to get the in car use case to work?
Thanks! Kurt
Phoenix Inverterinverter current draw
Anold Pande avatar image
Anold Pande answered ·
Hi Kurt..As we have come to know about victron inverters they do not draw that much power if they are no loads connected. You can basically run that inverter from your cigar lighter but you have to be careful on how much you load. Now back to your scenario it seems to suggest you might have a dead short on your inverter.... Is this a new inverter or u have used it before.
@Kurt Krueger
Check you have not wired negative and positive leads backwards. (This is a common mistake)
If those are correct then maybe the inrush current of the inverter is blowing the fuse. It may be worth running a dedicated system for it from the battery with an inline fuse of course for safety.
Phoenix Inverter product page
Phoenix Inverter Smart product page
