alan-whyman avatar image
alan-whyman asked
230 between live and earth
Hi on a 48/375 inverter I am getting 115volts between live and earth and 115volts between neutral and earth. But i need all of the 230 volts between live and neutral and 230 between live and earth meaning the neutral should be ground also. I noticed in the manual on page 12 this is possible with the larger inverters by moving a wire to a different connector but does not seem possible with this smaller one. Thanks if anyone can help i can solder to move the wire if any one knows where to put it.
Phoenix Inverter
Page 12 of the manual shows what to do at the small inverters (250, 375 and 500VA).
