skokie avatar image
skokie asked
Multiplus AUX I/O for Allow-to-charge in lithium system
It is possible to use in a Multiplus the AUX I/O for Allow-to-charge and the Temp Sensor for Allow-to-discharge commands.
Do I have to connect both connection for this function, or is it possible to connect only the AUX I/O alone for Allow-to-Charge, leaving the Temp Sensor connection unused and unconnected?
My BMS has only one free relay output left and I need only the charge disconnect function for the Multiplus.
MultiPlus Quattro Inverter ChargerLithium BatteryBMS
Welcome @Skokie ;-)
See if this helps: https://community.victronenergy.com/questions/36764/simple-switch-for-charger-off-multiplus-3000-12120.html
You need to get familiar with Assistants if you are going to use AUX I/O for ATC.
The temperature sensor for the Multi is not needed. Your BMS should take care of it and open ATC in case temperature is too low to charge.
skokie avatar image skokie commented ·
Hi @Stefanie, thanks for this quick response.
I think this will fit. When going back to my boat on Saturday, I try to get familiar with the assistants. ;)
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ skokie commented ·
Man könnte sich auch theoretisch schonmal damit auseinandersetzen. Der Samstag ist kurz ;-)
Hier ist eine Übersicht der verfügbaren Assistenten: https://www.victronenergy.com/live/assistants:overview_of_available_assistants
Und eine kleine Anleitung, um was es bei Assistenten überhaupt geht, wie man sie einfügt und konfiguriert etc.: https://www.victronenergy.com/live/assistants:start
Du brauchst den 'Charge current control'.
