Hi, I'm installing 2 x 175W RENOGY Mono Solar Panels wired in Series
I've ordered 10Awg cable, and run will be approx 18ft.
Batteries are 2 x 150Ah AGM wired in parellel.
Ive used the Victron calculator but I've had to guess a few figures as it's not on the Spec sheet for the panels.
It's telling me I need a 100/50 Controller? Does this sound right as I had to guess a few figures?
Also, I have an original panel that is linked to the existing split charge system via a rocker switch which I can change to charge either the starter battery or the leisure batteries. I'm going to leave this as it is and can then charge the leisure batteries with this as well as the two new panels effectively having 3 x solar panels in total charging the leisure batteries if required. However this panel has an existing PWM controller and I would like to also change this to a Victron at the same time, but I don't have any info on that panel as it came with the van. I think it's a 120W Pro Logic panel.
Therefore to summarise I need to purchase 2 x Victron Smart Controllers, one for the two new Renogy Solar panels. And one to replace the existing PWM controlled for use with the existing Pro Logic panel.
Can somebody please assist as I don't find it very easy to chose Victron controllers and I'm sure Victron would sell a lot more if they made it easier for customers.
