matteburk avatar image
matteburk asked
Teltonika Eye Sensor (BT temp,hum) in venus?
This would be really great to be able to add in Venus OS.... Look a lot like the Ruuvi but a lot cheaper but yet made by a pro company Teltonika.....
https://tktracker.shop/en/home/79-teltonika_eye_sensor.html
BluetoothTemperature Sensor
netweb avatar image
netweb answered ·
I think it would be possible, the wiki is quite detailed, and by the look of it it uses bluetooth advertising, it's not until you want to perform advanced configuration or firmware updates you need to enter a PIN code to pair the device.
Thus in my mind, it should work, you would maintain the devices with the Teltonika app, and Venus OS would detect the advertisements...
https://wiki.teltonika-gps.com/view/EYE_SENSOR_/_BTSMP1
I've been looking into this subject myself for alternatives to Ruuvi or the new Mopeka sensors, I also use home assistant and when looking for support of these new devices using bluetooth advertising the most difficult part is decoding the advertisments as can be seen in the issues in this GitHub [repo](https://github.com/custom-components/ble_monitor), the Teltonika wiki link above includes this documentation...
I'd say there is only one way to try buy one and give it a go, I doubt the Venus OS would support these by default, and support would have to be added to the code from [this repo](https://github.com/victronenergy/dbus-ble-sensors) to support the different hardware, but maybe could be adapted from the existing Ruuvi code
