techmaniac avatar image
techmaniac asked
MPPT shows in App but not on Display/Cerbo
Problem: The MPPT shows up in the Connect App, the MultiPlus does not (OK, I use the USB converter)
But: the MPPT does not show on the Display nor the Cerbo Device list
Any clue how to make the system Scan and find or add the MPPT or any settings which makes it appear? (Tried all obvious things)
System with Cerbo GX, PowerMeter, MultiPuls II and MPPT
Fresh install, all FW updated, all conntected vie VE.bus and terminated. ESS assitant installed and configured.
MPPT ControllersMultiplus-IIcerbo gxgx devicedashboard display
klim8skeptic avatar image
klim8skeptic answered ·
Do you have VE Direct cables between each mppt and cerbo?
techmaniac avatar image techmaniac commented ·
Okay, thank you, that directed me in the correct direction.
The empty was plugged into the ve.bus, but practically it has a ve.can.
Changed the cabling:
- cerbo->mppt via ve.can
- cerbo->multiplus via be.bus
Here we go! The question is whether I should try to get a ve.direct cable? Does it make things better?
klim8skeptic avatar image klim8skeptic ♦ techmaniac commented ·
If it is working, leave it as is.
I dont see any advantage using VE Direct over VE Can.
Warwick Bruce Chapman avatar image Warwick Bruce Chapman klim8skeptic ♦ commented ·
Especially since the only advantage of using VE.Direct will fall away with 2.90 (remote configuration via VictronConnect).
