fivenines avatar image
fivenines asked
Phoenix Inverter neutral
There are two versions (as of 4/18/22) of the 120V Victron Phoenix Inverter VE.Direct for the US – NEMA 5-15R and GFCI. I have found online inconsistencies regarding the internal neutral bonding capabilities.
The manual apparently covers both models. Appendix A in the manual states there is an internal jumper. Some online references state the NEMA 5-15R model has the jumper and the GFCI does not, and some state the opposite.
I also found references to model and manual updates, but can’t confirm release dates.
Do both models have the internal jumper? If not, which model has the jumper?
Manual: https://www.victronenergy.com/inverters/phoenix-inverter-vedirect-250va-800va#manual
4/19/22 Update: links describing the confusion and inconsistency.
(NEMA version has single receptacle, GFCI version has typical two receptacle “outlet.”)
NEMA version w/o jumper:
https://community.victronenergy.com/questions/20685/bonding-neutral-and-earth.html
Unknown version:
https://community.victronenergy.com/questions/28130/phoenix-12250-inverter-neutral-grounding-and-other.html
Possibly NEMA version:
https://community.victronenergy.com/questions/83306/my-client-cant-realise-the-neutral-ground-connecti.html
Video shows NEMA version:
https://community.victronenergy.com/questions/101023/phoenix-121200-how-to-connect-the-output-neutral-t.html
https://www.youtube.com/watch?v=ehK0uYNtaIY
Appendix A in manual as linked above appears to show NEMA version.
Update 5/20/22
I purchased two Phoenix VE.Direct Inverters: 12V 1200VA 5-15R and 12V 500VA GFCI. Both have the capability to change the neutral bonding (bonded to non-bonded) via an internal jumper wire as described in the manual. I verified the capability by testing continuity with a multimeter.
Also, the GFCI is tamper resistant.
Victron, you need to do a better job of documentation
Phoenix Inverter
