trostek avatar image
trostek asked
control Cyrix or BP with BMV instead of BMS
Hi!
Is it possible to control the disconnect function in Cyrix Li-ct (or Battery Protect) with the relay function in BMV712 (instead of the BMS)?
I would like to use the BMV alarm functionality to disconnect the alternator from the house battery when SOC gets close to 100%.
BMV Battery MonitorBattery ProtectCyrix Battery Combiner
Paul B avatar image
Paul B answered ·
Yes you can do this as the BMV relay contacts that are normally N/O you can reverse the relay to be N/C thuis opening on a Alarm
astor avatar image astor commented ·
Hi @Paul B
It is possible to control in the same way Cyrix CT via BMV?
Thanks,
Dobri
