goncalo avatar image
goncalo asked
Keep Batteries Charged not reaching 100% - not using Bulk?
I have 18 LFP cells in series, connected to a Multiplus-II 48/5000/70-50, but have not installed solar PV yet. I'm trying to fully charge the batteries but unsuccessfully. It seems that both Scheduled Charging and Keep Batteries Charged only use the "Float" setting without going through the cycle "Bulk -> Absorption -> Float". What seems to be happening is that at the Float voltage (60.3V for my system, 3.35V per cell), the charging current quickly decreases and the battery does not go higher than 68% SoC (as calculated by the SmartShunt that is also installed in the system).
Is there a way to force the Multiplus into Bulk charging mode?
Maybe this is a problem with my settings, here is a summary (values in parenthesis per cell). Please let me know if more information is needed:
  • DC Input Low Shutdown: 52.0V (2.88)
  • ESS Cut-off Discharge: 54.0V (3.00)
  • Absorption: 61.2V (3.40) 2h time
  • Float: 60.3V (3.35)
  • ESS Sustain: 60.3V (3.35)
battery chargingmultiplus ve.bus
nickdb avatar image
nickdb answered ·
Why is your sustain voltage so high? That's not right.
Are these voltages not pushing the limits of the multi's charger?
7 comments
goncalo avatar image goncalo commented ·
It probably is too high indeed. What do you suggest the sustain voltage should be?
Yes, a bit higher than usual, but within the limits of the multi. I’ve seen examples of people with the same amount of LFP cells in series with no problems.
nickdb avatar image nickdb ♦ goncalo commented ·
If I compare to pylon and others, sustain seems to be around 2 to 3V above dynamic cutoff depending on pack voltage.
So thats around 3.125 to 3.2V per cell on the batteries we use.
goncalo avatar image goncalo nickdb ♦ commented ·
Thank you for the help! I’ll change the Sustain voltage.
Any thought regarding the main question?
It really shouldn't matter. If ESS is working fine (it doesn't seem to be due to settings) then it will charge correctly and vary between bulk/absorb depending on PV and charge level.
Lithium doesn't really do the typical bulk/absorb/float cycle.
edit: I take it your pack isn't managed by a BMS? Usually this just tells the multi what it wants and everything follows.
I was also thinking that maybe this is happening because I don’t yet have the PV system installed…hopefully the installer will come do that next week. For now I was just testing the system with the batteries.
I do have a BMS, but it does not communicate with Victron. So basically it just acts as a fail safe in case of high/low voltage and also actively balances the cells.
Depending which one you have, there are some community members that have written generic serial drivers etc. You kind find those topics in the modifications section.
Yeah, I'm following a Telegram group who are trying to write some software to make this particular BMS work with victron.
Regarding my first problem, it is now solved. It was an issue with the particular firmware version that came installed with my Multi (481), so updating the firmware fixed it. Lesson learned for the future, first update to the latest firmware before trying to understand the problem better hehehe.
Thank you for your help anyway.
goncalo answered ·
In case someone reads this coming from google or something, the problem was fixed by updating the Multiplus's firmware to the latest version. Lesson learned for the future: keep the software up to date!
