Hi My remote console shows 7h 17min but vrmportal shows 179.33h? I guess the portal is the right one since the dc power only is 13 w on 200ah battery
/Mattias
/Mattias
Maybe something you can look at?
Can you let me know which language do you have selected for the gui in the display menu? Swedish perhaps?
There is a mistake in the Swedish translation that translates "d" of days as "h", we will correct it. Thank you for confirming it.
@Kevin Windrem This is why you can't reproduce the problem.
There appears to be a bug in some of Victron's code, but that is only used for time values greater than 1 day. The code is secondsToString () in utils.js.
The stock battery menu item uses a different function that does work on time to go values so I've copied that code for use in the GuiMods flow and mobile overviews.
I could not duplicate this problem here on my Cerbo, so let me know if GuiMods v5.20 fixes the problem. If it does NOT fix it I'll keep digging.
Hi.. v5.20 seems to have fixed it... se pic below.
Good work Kevin!
/Mattias
36 People are following this question.
