erichabg avatar image
erichabg asked
How to switch power assist on an off via node-red?
For some years I have controled my Multiplus (I not II) with a raspberry pi via two DAC and the assistants for "Charge current control" and "Input current limit control".
Since now an extension of the solar plant took place, I wanted to use a Cerbo GX instead of the Raspberry Pi and do without the DA converters but regulate this purely via software. More precisely, by means of Node-red on the Cerbo GX.
But unfortunately I miss the possibility to regulate the charging current (of the Multiplus charger) and also the regulation of the power assist mode does not behave as expected.
I have installed the "large" Firmware (V2.82) on the Cerbo GX and I have enabled node-red and I'm using the node-red-contrib-victron node.
Devices are: Cerbo GX, Multiplus 24/3000, BMV-700, MPPT250/60, MPPT 75/15.
The AC charger node reports "There are no ac charger services available. Please check that a ac charger is connected or try a different node." The "multi control" node has no input for charger settings too.
Question: How can I control the Multiplus charge limit?
The input current limit can be read and writen by "Multiplus Input 1 AC current limit" in and out node but the behaviour is a little bit strange.
From 3 to 16 A current limit, all works as expected. i.e. when I set it to 5 and read it back afterwards, i got 5.
But when I set it to '0' , i got '3' when i read it back, but the Multiplus stops Power Assist mode (as expected). Is this (set to 0 to disable and set to >=3 to enable) the only way to enable/disable power assist?
Regards
Erich
Node-REDcharge current limitpowerassist
