What is difference between: Multiplus C 24/800/16-16 and Multiplus 24/800/16-16?
Thanks
Thanks
The "C" stands for Compact, while the other model has a new case and is a bit smaller in size.
See also the data sheet for each model here to compare specs:
https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-inverter-charger--800VA-5kVA-EN-.pdf
https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-500VA-2000VA-EN.pdf
27 People are following this question.
