Martin Coetzee avatar image
Martin Coetzee asked
Overload alarm leading to error 17
First time i am getting this in day time, 2 x 5kva parralel. i also got a overload error at the same time. I have lowered the input current on my victrons. It was at peak charging at was getting in just under 6000 watts from my panels. Max watts is 8800.
error
Paul B avatar image
Paul B answered ·
Another possibility to look at
The length of the Battery cables to EACH unit, They must be the SAME length
just maybe one of the cables is longer and causing a issue.
this is just a thought and something to check
willemoud avatar image
willemoud answered ·
I suggest to double check the isolation switches
as they may be causing the problem.
