aglowack avatar image
aglowack asked
Shunt stauts isn't accurate.
I installed a Victron shunt with my new Dakota lithium starting battery. The shunt is wired correctly and I can see draw when I start my engine or when my graphs are on. I can also see the charge when running my engine or charging wit the charger. I've checked status while I am fishing and the draw down and recharge seems fine. The last two trips I check the status before trailering my boat and the shunt showed 92 on one trip and 94 on the other. I check again when I got home and both times the shunt showed 100%. I hooked my charger up yesterday and it charged for about 35 minutes before going into float mode so the battery was not at 100%. When I installed the shunt I charged the battery to 100% and synchronized the shunt. Any ideas?
installationaccuracy
nickdb avatar image
nickdb answered ·
How have you configured the shunt?
Did you match the settings to your battery?
aglowack avatar image aglowack commented ·
I think so I have the following settings for my 60ah lithium battery, should I have the Battery starts syncronized set to off (blue ball to the left)?:
Battery capacity: 60 ah
Charged voltage: 13.2V
Discharge floor: 20%
Tail current 4.00%
Charge detection time: 3m
Peukert exponent: 1.01
Charge efficiency factor: 99%
Current threshold: 0.10A
Time to-go-averaging period: 3m
Battery starts synchronized: the blue ball is to the right.
aglowack answered ·
Tail current 4.00%
