Can somebody explain the difference of installation suggestions ESS DC PV at page 6 in this manual https://www.victronenergy.no/upload/documents/MultiPlus-II-to-MultiGrid-and-MultiPlus-comparison-EN.pdf ? Advantages and disadvantages?
one uses an external current sensor, using this you don't have to wire all users through the Multi. It can safe re-wiring of your system.
(note that when installing Multi further from grid-panel you cannot use extension wires for the sensor, and you'll have to use an energy meter wired to Venus instead).
5 People are following this question.
