wudycool avatar image
wudycool asked
communication pylontech ->old mppt ve.can ->ccgx
hopefully simple question.
I have since 6-7 years a ccgx with old 150/ 70a mppt ve.can working. Veryvell by the way.
now i bought two pylontech batteries, how do i connect them all together? where do i plug in the terminator(s)?
thank you very much for help!
(sorry i ask question already here with no answers
https://community.victronenergy.com/questions/179/connection-type-bdy-ccgx-mppt.html?childToView=124546#answer-124546 )
CCGX Color ControlPylontechVE.Can
Hi @wudycool,
maybe this is of help for you: https://community.victronenergy.com/questions/97434/ccgx-with-two-canbus-inputs.html
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
AFAIK the battery requires the canbus speed set to 500kbit/s, which makes it impossible to daisy chain with your MPPT (VE.Can 250kbit/s). Either you change to a Cerbo GX (two independent canbus ports) or connect your MPPT via VE.Direct to your CCGX.
wudycool avatar image wudycool commented ·
thank you for this information.
ve.direct is not possible. its the old version off 150/70 ve.can. i will sell my ccgx and get cerbo gx.
wkirby avatar image
wkirby answered ·
@wudycool
Old model VE.Can MPPTs are not supported.
See below paragraph from the Pylontech compatibility manual:
MPPTs with a VE.Can port
New Model (2019 and later) VE.Can MPPTs are also supported from firmware version 1.06 and above. Be aware that some GX devices (e.g. CCGX) only have a single CANBus interface, and that is required for the battery communications. So if you use a new VE.Can MPPT, it must also be with a GX device that has more than one CANbus interface, e.g. the Cerbo GX.
Old model VE.Can MPPTs (pre 2019) are not supported.
Link to the manual: https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
