netweb avatar image
netweb asked
Recommended Fuse Size Missing from MultiPlus 500VA - 1600VA Manual
I've just been reading the Wiring Unlimited document and in section 4.1 it states:
Though this does not appear to be in the Rev 06 MultiPlus 500VA - 1600VA Manual:
I've scoured the document for "recommended", "fuse size" etc and cannot find any references for this for any of the models
Is there a reason why these are excluded from the manual here as I'm missing or misunderstanding something?
Specifically I'm looking for the 12/500/20 recommended fuse size if someone knows that in the meantime.
Thanks.
fusesdocumentation
Alexandra avatar image
Alexandra answered ยท
@netweb
I suppose because most people who buy the smaller ones dont fuse? Just guessing.
Anyway there are different types of fuses for DC. 500va รท 12V is 41.666A so a fuse rated for that will work.
16mmยฒcable fine strand battery cable can carry 100A. So 100A one will work as well. Since fusing is there for cabling I would go with that. The victron midi fuse has a neat one in that range
netweb avatar image netweb commented ยท
Thanks, I've gone for a 63A Noark DC Circuit Breaker where I'm using 100A cable from the inverter DC output to a positive busbar
0 Likes 0 ยท
