offrocker avatar image
offrocker asked
Fine control of Phoenix inverter's voltage and frequency
I have my Phoenix inverter (500-watt model) set to 121 volts, 60 hertz. According to a reliable multimeter, the actual output is 120.3 volts, 60.18 hertz.
Obviously the current setup is fine for essentially all purposes, but I was wondering if Victron have any interest in implementing finer control of the output. I tried typing in a decimal value for voltage, but that resulted in the inverter setting its voltage to the maximum. Is perhaps the hardware not capable of finer accuracy? I'm just curious.
Phoenix Inverter
