Hi everyone,
I have a grid lost alarm where the MultiPlus 48/5000/70-100 cannot read grid when there is grid power and it is draining the battery.
Please assist on what could be causing this problem and how I can fix it.
Thanks
Hi everyone,
Thanks
Before all: The grid trip switch is up?
Is there actually grid power on the contacts of the inverter?
If so:
Grid voltage and frequency ok? If not within set up tolerances it wont connect.
Try switching off "UPS function" since this is a setting making the system vulnerable.
If still no success try the "weak input" option, but be aware that this is influencing the max charge current...
25 People are following this question.
