Might it be possible to integrate an USB network sharing service into GX-Devices?
I´m using a external Raspberry PI to connect an MK3 adapter and could connect anywhere via Intranet to this Raspberry and use the connected USB-devices the same way as local connected devices.
Even firmware updates are possible that way.
But while the raspberry is powered from a Multiplus II inverter output, resetting the device means cutting the branch I´m sitting on.
As it may not an technical difference using the GX or an external Raspberry PI, might it be possible to integrate this service into the GX, or to to integrate a option to run the installation by the user.
VirtualHere is a commercial product, which allows to share any amount of connected USB-Devices to Remote Clients. The license costs about $49. For enduseres, there is a version for RaspberryPI free of charge, able to share one device.
I´m afraid that this license might not cover upfront installation on commercial products.
But if user could trigger the installscript
curl https://raw.githubusercontent.com/virtualhere/script/main/install_server | sudo sh
by himself without having to root the device...
This could produce added-value to many GX-customers...
Regards
Bergy
