mrsoapsud avatar image
mrsoapsud asked
Display PV Voltage from web on ColorControl
I have a ColorControl GX and a Multiplus Compact and I'd like to see the PV Inverter output on the ColorControl.
The PV Inverter isn't one of the ones supported directly by the GX.
I can't connect an AC sensor on the PV output to the Multiplus because the Temp Sensor input has a Temp Sensor connected to it.
I can't monitor the PV output with the CG EM24 that I have because they're not in the same place.
I can, however, retrieve the PV Output Voltage from the web site suggested by the Inverter manufacturer using a script combining "curl", "awk", and "sed"! Is there a way I can dump that value into a register in the GX so that it's interpreted as the PV output for the display?
Thanks in advance
Martin
Modbus TCPgx device
mrsoapsud answered ·
Bump! Anyone have any pointers as to where I'd start on this?
Thanks
