Hi i have 20 off Cerbo device to configure all with same settings, to do this manually will take some time, is there a way to do one unit test it, and then copy its configuration to the others?
Ok thanks, what a pain, quite surprising this has been overlooked when you consider the number of variables you can configure on a go device. Takes me ages to try and remember all areas to select, enable, and scale.
31 People are following this question.
