tef avatar image
tef asked
SMA on AC-Out disappeared
Hello!
I have a 3 phase ESS system with a ColorControlGX, 3x Multiplus 2, Fronius on AC-IN and a SMA Tripower Inverter on AC-OUT.
Everything was working fine but a few days ago, the SMA on AC-OUT disappered from the CCGX and VRM portal. I haven't changed anything.
The device entry is still shown in the "inverters" menu but not in the "detected ip addresses" menu of the CCGX.
I checked the following:
  • TCP Server is enabled
  • UDP Server is enabled
  • modbus ID of the SMA is 126 (3+123)
  • ping is successful
  • telnet to port 502 is successful
  • inverter data is shown in sunny explorer and in a logging application with UDP communication
  • restarted the whole system
  • updated to the most recent CCGX FW
  • manually added the ip in the CCGX
  • did several inverter scans in the CCGX
  • changed all relevant settings in the inverter and ESS menu
Is there anything else I could try?
Thank you!
Best regards
Thomas
CCGX Color ControlAC PV Coupling
tef avatar image
tef answered ·
The problem is solved.
I disabled and re-enabled the UDP and TCP Server of the SMA inverter.
cioringa avatar image
cioringa answered ·
Hello, I have the same problem, my SMA tripower dissapears and reapears i also have Fronius inverters connected two of them and they work ok but the SMA is on and off intermitently.
I tried enabling and disable UDP TCP but nothing ... sometimes i just restarted the SMA inverter and it reapeared.
Any ideas ?
