I have a Peak Power Pack. Is is possible to control the outputs via app if I buy a VE.Direct Bluetooth Smart Dongle?
Yes. From the datasheet:
Link to the datasheet:
https://www.victronenergy.com/upload/documents/Datasheet-Peak-Power-Pack-EN.pdf
Hi @WKirby
Yes these functiosn are normal.
In the Datasheet you find also:
-> Hold down for 5 seconds: storage mode, blue LED flashes 10 times , yes that woeks fine
That is the Hibernate mode.
-> But how i get back the output because when in Hibernate the Bluetooth Smart Dongle no longer works. And the button does not react on any input (pushed for 30 min ON or allways ON)
PPP - 12,8V/8AH - Version 1.08
Is there something that i'm missing here?
27 People are following this question.
