wildebus avatar image
wildebus asked
Venus OS Version Checking for Latest "Large" version
Running a Cerbo GX with V2.72-large-19 firmware.
When I run a check for latest firmware and set the Image type to "Large", I get an error:
If I leave it at "Normal", the check works and I am offered v2.81. But I want the Large version as I am using Node-Red for some key functionality.
Should the Check for Updates work when checking for Large images? or is it still a manual update process?
Venus OSNode-RED
Louis van der Walt avatar image
Louis van der Walt answered ·
You should disable auto updates for the Large image. It is not yet supported.
See the first item under Step 3 for how to install the large image.
wildebus avatar image wildebus commented ·
Hello. Yes, auto-updates is disabled. Doesn't mean you can't hit the button to look though ;)
(you may notice in my screenshot that "Auto update" is set to 'Check only'?)
Hi @Wildebus,
the large image is not fully implemented yet into the update tree. It's still manual update, but hopefully this feature will come soon.
Thanks. When I saw the option to select the 'Large' image type when checking, I though maybe the download and install option may have come live for it as well as the Normal ones.
rkflyer avatar image
rkflyer answered ·
If large isnt installed into the update tree what is the correct procedure to update? Im currently on 2.70
Also do I need to save my configuraition and/or Node Red flows before any update.
Great work on this Large OS... Saving the pennies to upgrade to a Cerbo right now.
Not necessary to save configuration or flows. Only for versions prior to 2.70.
For installation see here: https://www.victronenergy.com/live/venus-os:large#how_to_install
