stewarthanford77 avatar image
phoenix 12/1200 connectivity to a cerbo gx
I have a customer that wants to install a phoenix 12/1200 ve. direct inverter into his coach with a cerbo gx and gx touch 50. will the ve. direct port allow him access to turn the inverter on and off. or do i have to install a remote switch to turn it on and off from. They want the gx touch for the visibility of items to include the solar that I will be installing on there roof. Main question is just is the phoenix 12/1200 capable of communicating with the Cerbo GX and GX touch.
Phoenix Inverter
so with that connection do i use the VE to VE or the VE to usb?
wkirby avatar image
wkirby answered ·
Yes, the VE.Direct inverters will communicate with a GX device.
Here is a little 250VA Phoenix Inverter connected with VE.Direct to a GX device. The Switch can be selected from the menus.
I hope that helps.
stewarthanford77 answered ·
Thank you for your response.
