softwarecrash avatar image
softwarecrash asked
Ve.Direct Framehandler Wrong on 150/70
i have a little program, based on this framehandler
https://www.victronenergy.com/live/vedirect_protocol:faq
so mit most devices it works perfect.
but with a 150/70 it doenst work, the problem is that the device append a HEX message direct after the Checksum byte without linebreak or something.
the message from the device is:
PID     0xA071
FWE     315FF
SER#    HQ2324YAH29
V       22000
I       0
VPV     0
PPV     0
MPPT    0
CS      0
OR      0x00000001
ERR     0
LOAD    OFF
H19     1077
H20     0
H21     4
H22     117
H23     921
HSDS    16
Checksum        ▒:A2001002200000008
                                   :ADBED00750806
                                                 :AD5ED009708EA
                                                               :A8DED00970832
so i tried all linked arduino librarys and other examples linked in this froum and support pages, but no on can handle this message.
anyone a idea, or can update the framehandler example?
thank you
VE.Directcommunication protocolarduino
Hi @softwarecrash
The reference frame handler should filter out the hex message. You say that you have a program based on this framehandler. Can you share the code somehow so people can take a look at it? And perhaps provide some more information on what is going wrong according to you? For example, are you missing the frameEndEvent call, do you get wrong values, etcetera.
Kind regards,
Thiemo van Engelen
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @softwarecrash
If the code that you have is almost completely a copy of the reference frame handler, then the
bool hexRxEvent(uint8_t c)
function should return true when c == '\n'. This will reset the frameHandler state to IDLE and following frames should be parsed again.
Kind regards,
Thiemo van Engelen
softwarecrash avatar image softwarecrash commented ·
hello,
here the two files with the code, its similar to the arduino libraray that linked in the docs
framehandler.cpp
https://pastebin.com/xUg5WJMJ
framehandler.h
https://pastebin.com/g2AQmuMS
so the device attach in every text message the HEX message at the end and over more lines., in this the HEX "Filter" will not work.
i recive with this device evertytime a checksum error.
it looks like a missing newline or termination for the checksum calculation
Hi @softwarecrash
So the problem is indeed that the hexRxEvent should not always return true, but only when c == '\n'. With your current (that always return true), all characters of the hex message are added to the checksum. By only returning true when c == '\n', it stays in the RECORD_HEX state while the hex message is still going on and only leaves the frame handler in the proper state for the start of the text frame.
Kind regards,
Thiemo van Engelen
softwarecrash answered ·
@Thiemo van Engelen (Victron Energy staff)
thank you for your answer,
so i double checked the example code and mine, badly in the example code the hexRxEvent() function is not described, so i added a simple switch to it to stay in the hex_record state until a newline is income, but without change.
bool VeDirectFrameHandler::hexRxEvent(uint8_t inbyte)
    if (inbyte == '\n')
        return true;
    else
        return false;
the hex data was ignored or dripped, but the checksum was calculated with some extra characters.
so without the hex data it works like a charm, but the new device append without asking on every frame a hex message.
can you provide a example that work, or a hint what i must modify that the hex data ignored and not calculated with the checksum?
thank you
Hi @softwarecrash
The attached code works on a VE.Can SmartSolar 150/100, which has the same behavior with respect to hex messages.
There was also an error in your code:
for (int j = 0; j <= veEnd; j++)
This should be:
for (int j = 0; j < veEnd; j++)
This change then also requires changes in the part below it that copies new names. Here it should allow veEnd to go beyond the max index and check before copying if this is the case. (I did not yet do this in my code)
With kind regards,
Thiemo van Engelen
vedirectframehandler.zip
hi @Thiemo van Engelen (Victron Energy staff)
thank you for the atached code, i have tryed it. but the behavior is the same, it result in a wrong checksum, so i think in the checksum part it grab ord add more than the checksum byte.
with a mppt device that only send the text message, all okay, but with device was attach a async hex message at every text message it result in a checksum error.
for test i have wrote a short emulator that send two different text messages, but the calculated checksum value is the same for both messages, so i cant find what goes wrong with the calculation of this. or add or missing the start line after hex?
Hi @softwarecrash
We have provided code that works in our setup and we cannot debug your code. That is something you have to do yourself. The only thing we can do is check whether the received data is as expected if you provide a (binary) dump of the data you receive from the MPPT. So the bytes receives from the MPPT during a period of time that spans multiple text and hex frames.
Kind regards,
Thiemo van Engelen
Hi @Thiemo van Engelen (Victron Energy staff)
You are right, your code works perfect!
funny note, it doenst work with the one 150/70... the one test device have some fault, maybe logic level issue, the other works great with the source.
thank you verry much for your support and help!
VE.Direct protocol FAQ
