48v-on-56north avatar image
48v-on-56north asked
Mixing Pylontech 3000 and 3000C using LV-Hub
Extending a Pylontech battery from 4 US3000 to 4xUS3000 + 8xUS3000C using an LV-HUB. Connecting to Cerbo GX via BMS cable type B. So far not able to make the Cerbo see all 12 batteries (Total capacity and live currents) at the same time. I can get up to 8 batteries showing by eliminating the LV-HUB from the setup. I can also get 8 showing with the HUB but not 12.
I realise the LV-HUB comms set up is very different for US3000 and US3000C. Hence I have also tried to create 2 stacks of 4 3000C followed by 2 x 3000. This means each stack is limited to 6, and both stacks are using 3000C as master battery. No joy getting both stacks to show on the Cerbo. (Even though one stack does show)
Has anyone managed to mix US3000 and US3000C with a Cerbo GX in a single system ?
I'm out of options but still keen to be able to monitor and control charging as a single 12 battery system via Cerbo GX
Any hints / tips / suggestions welcomed,
MK
Pylontechpylontech lv hub
Jack Peters avatar image
Jack Peters answered ·
Use a US3000C as master, then all four US3000's, then the rest of the US3000C's. No LV Hub required.
48v-on-56north avatar image 48v-on-56north commented ·
You're the man, ;) It worked. And yes I realized its all about counting in binary with someone that can only count to 8. Thanks, MK
Onwell Dzobo avatar image Onwell Dzobo commented ·
Hi Mk.... I am facing a similar challenge, slightly different though in the number of batteries. I have 9*US3000 and 2 by US3000C.... How do i configure these as i have so far made the US3000C the master on the 3 groups i have created but on the LVHub, Only been 2 flushing is flushing indicating only 2 grps are being seen. How can i get to see the all the 3 groups.
48v-on-56north answered ·
Hi Jack, I'll be testing your suggestion tomorrow, fingers crossed, Cheers, MK
