ppr avatar image
ppr asked
MPPT RS450/200 display contrast
Hi
Does someone know if it is possible to adjust display brightness on the RS MPPT?
The contrast on mine is so high I can not read anything. Thank you.
I wont believe that this can not be adjusted via software.
MPPT Controllersmppt rs
ppr avatar image
ppr answered ·
thats how it looks - not readable
please victron, add the option for contrast.
aart-vroegop avatar image
aart-vroegop answered ·
At the moment, brightness is not adjustable in this product. Can you share the serial number of the MPPT RS 450/200? This will help to tackle the brightness issue adequatly. Thanks.
BR, Aart
ppr avatar image ppr commented ·
HQ2137XXTFQ
Thank you
But I think best way is to add it in the firmware
riblaisqc avatar image
riblaisqc answered ·
Same problem for me on my MPPT RS450/100. The contrast is bad and there is no adjustment.
alaskannoob avatar image
alaskannoob answered ·
Sorry I don't have an answer for your question (apologies), but since you are using an MPPT RS, are you using fine stranded PV wire into it that is comprised of strands no larger than .016" diameter? If you are, can you share what kind of PV wire you're using and where you got it?
