solarjunky avatar image
solarjunky asked
Feeded in Energy does not comply with Venus GX
Sorry if this was asked before. I did a research but did not find helping info.
If I watch on electric meter of my house installation it says, that my system feeded 16 kWh into the grid in nov. + dec. 2021. - fine !!
If I watch my installationsite on internet (Victronenergy.com), it states that my system feeded in 63 kWh on "solar" menu.
When I change to "systemview" it states that it would be 103 kWh.
How do I configure my system correctly ?
I have a 1-phase application. On Phase 1 there is a Multiplus 48-3000 and a SunnyBoy 3.0 from SMA.
I use a ET 340 gridmeter, a Venus GX with Firmware 2.73 and 3 Pylontech 2500 Wh batteries.
Thx for your support.
power meter
The ET340 is your problem. In a 3-phase grid and a 1-phase ESS you should use an EM24 instead. They work a bit different and the ET340 will give you some wrong values in the VRM portal but the system will still work as it should it is only the visualization/summary.
In a 3-phase grid and 3-phase ESS the ET340 would work well.
