svreverie avatar image
svreverie asked
Victron MPPT 100/30 with FullRiver DC105-12 AGM Battery Bank - Configuration
Hi
I am sharing the battery setup information I received from FullRiver Energy.
My setup is as follow:
4 - FullRiver DC105-12 AGM Batteries Connected in Parallel for a total system of 12V / 420Ah.
I am using a VictronSmartShunt in addition to 2 Canadian Solar 250W Solar Panels Connected to Victron MMPT 100/30 charge controllers. Have two of the 100/30 one for each panel.
The configuration I received from FullRiver to configure the battery setting is as follow:
  • Battery Volt: 12V
  • Max charge Current: 105A (you’d have a theoretical max of ~30-40A)
  • Absorption Voltage: 14.7V
  • Float Voltage: 13.6V
  • Equalization Voltage: 14.7V
  • Re-Bulk Voltage offset: 0.6V
  • Absorption Duration: Adaptive
  • Maximum Absorption Time: 4 Hrs
  • Tail Current: 8A
  • Equalization Current Percentage: 100%
  • Automatic Equalization: Disabled
  • Equalization stop mode: Fixed Time (lowest it goes since it’s disabled)
  • Maximum Equalization Duration: Lowest setting it can be
  • Temperature Compensation (mV/°C): -24mV/C
  • Low-Temperature Cutoff (optional): -40C
Hope this helps those of you with this type of setup.
MPPT SmartSolarVictronConnectAGM Battery
Alexandra avatar image
Alexandra answered ·
@SVReverie
Nice. Thank you for sharing and keeping with the Victron Community spirit.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
VictronConnect Manual
Download for iOS / Android / Mac / Windows
