I am looking under the advanced feature tab in the VRM and see a section titled “Battery Temperature Sensor 277”. Which sensor do I use in order to see data in this field. I have a 3k multi and a Cerbo. Any help will be appreciated.
They make a temp sensor just for the GX(also believe it works for the multi/quattro) line of device. It is different than the one used for the BMV. Once you have one connected to the Cerbo, you just go into the settings and enable it with a few parameters. You should start to see data flow there after.
anynfurther thoughts on this?
27 People are following this question.
