dim-avlo avatar image
dim-avlo asked
Voltage correction
Hi There, i would like to ask if the power assist or any other relative function or setup on a multiplus 2 can correct grid problems like voltage drop . I have a pv system connected to battery and grid available but the grid characteristics are bad from time to time and cable lengths to long ( replacing the m is not an option), i was wondering when in power assist if the output voltage of the multiplus can be corrected dynamically or it synchronises with the grid?
Or if there is any other way to use my system as a rectifier
Thank you
Multiplus-IIpowerassist
The Multi/Quattro will only pass-through the incoming grid voltage/frequency.
