JedTheFed avatar image
JedTheFed asked
Power assist does nothing, never activates
Hello, I have...
Dual Multiplus 3000 currently running in parallel on 30 amp shore power
bmv 712
cerbo gx
touch 50 screen
800 amps of lifepo4
Power assist on in both units
When I set "input current limit" to 15 amps and I run 20 amps of load the power asssist never helps out. The system just keeps charging the batteries. It never actually shows the correct amout of amps bieng drawn. Can this be corrected?
Gary
Multiplus-IIcurrent limitpowerassist
Kevin Windrem avatar image
Kevin Windrem answered ·
I believe the current limit setting is for EACH Multi in a parallel system. Try setting the current limit to 7.5 amps (15 amps total).
