Eran Rundstein avatar image
Eran Rundstein asked
Multiplus continues to charge even if disconnected from Cerbo GX
Hello everyone!
I have a REC BMS Q connected to my Cerbo GX, which is also connected to a Multiplus 3000. I have enabled DVCC/SVS/STS like the REC BMS manual suggests and I am running an unexpected problem: when I disconnect the BMS from the Cerbo, or when I disconnect the Multiplus from the Cerbo, the Multiplus continues charging.
I would've expected that if there is loss of communication the Multiplus will abort charging. Going over an Orion BMS manual, which is also Victron-CAN compatible, they do indicate that loss of communication should prevent the Multiplus from turning on.
The Cerbo GX manual also indicates that should be the case - in the section where they describe what happens if you power up the CerboGX from the Multiplus AC ouput. But in my setup for whatever reason if I power up the Multiplus with the Cerbo turned off, it is still happy to charge - which is unacceptable for safety reasons...
Does anyone have any idea what I am missing?
I'm attaching some photos of the information displayed on the Cerbo.
Thank you!
MultiPlus Quattro Inverter Chargercerbo gxmultiplus ve.bus
Its like that indeed. Not perfect, but is what it is. For best safety, make the BMS control a relay.
I can’t remember where, but a long time ago I wrote the same, but then more verbose, and end conclusion: for a safe system with 3rd party battery, have the safety features (relay) built into the battery/bms and controlled by the battery/bms.
Just like all the professionals do: BYD, Pylon, Battleborn, Freedomwon, and so forth.
Eran Rundstein avatar image Eran Rundstein commented ·
Thank you. The BMS does have a relay, but I was hoping for a more elegant solution given all these fancy buses. Oh well :/
