For the life of me, I can't figure out where to set my 2 MultiPlus 24v to 180 split phase. I've updated the firmware on both, but I don't see anywhere to set them in split phase. Help!
Must be configured to operate in Parallel using VE Bus software.
https://www.victronenergy.com/upload/documents/Manual-VE-Bus-Quick-Configure.pdf
Thank you. I ended up setting them in split phase with the legacy apps. This article had me particularly annoyed because nowhere did it mention split phase other than the title
38 People are following this question.
