I added VE-Bus Smart Dongle, with separate temp sensor, and connected it per the manual. However, it does not turn on. I thought maybe it was bad and replaced it but new one does not turn on either. Any suggestions?
You bolted the temp sensor to the positive battery terminal? Fuse ok?
25 People are following this question.
