azure-2 avatar image
azure-2 asked
problem connecting Smart Battery Sense to Smartsolar 250/85
datasheet-mppt-250-60-up-to-250-100.pdfI'm configuring the Smart Battery Sense and Smartsolar 250/85. I have created the network on the Smart Battery Sense but I can't select any options in the Smartsolar 250/85 to connect to a VE network.. The data sheet says it can... See attached
Please assist.
MPPT ControllersSmart Battery Sense
azure-2 avatar image azure-2 commented ·
Sorry, one thing I didn't mention was that I'm trying to connect both to the same bluetooth network.. See screenshots attachedWhatsApp Image 2021-12-17 at 13.49.51 (1).jpeg
Serial number of the Smartsolar is HQ1739YD7RS
kevgermany avatar image
kevgermany answered ·
VE networks use either a normal LAN cable or ve direct cable, depending on the network. The photo shows a white VE direct socket bottom left. Also two VE bus green sockets. These use normal LAN cables, which must be fully wired, some aren't. There should be an RJ45 socket on the MPPT
The smart battery sense/MPPT connection is bluetooth, pairing usually defaults to 000000 (six zeroes)
The question is about the VE Smart Network (via Bluetooth)
https://www.victronenergy.com/media/pg/VE.Smart_Networking/en/introduction.html
Sorry, one thing I didn't mention was that I'm trying to connect both to the same bluetooth network.. See screenshots attachedWhatsApp Image 2021-12-17 at 13.49.51 (1).jpegWhatsApp Image 2021-12-17 at 13.49.51.jpeg
Matthias Lange - DE avatar image Matthias Lange - DE ♦ azure-2 commented ·
Your MPPT is to old and not compatible. See the list in the link above.
Product
Old Incompatible Part-number
New Compatible Part-number
SmartSolar MPPT 250/85
SCC125085210 (before s/n HQ1811)
SCC125085310 (before s/n HQ1811)
SCC125085210 (after s/n HQ1811)
SCC125085310 (after s/n HQ1811)
azure-2 answered ·
Serial number of the Smartsolar is HQ1739YD7RSWhatsApp Image 2021-12-17 at 13.49.51.jpegWhatsApp Image 2021-12-17 at 13.49.51 (1).jpeg
