tezza5555 avatar image
tezza5555 asked
Using Multiplus II GX to apply a "Freshening Charge"
My SBS Super Safe T 12V 190amp/hr batteries state in their manual that once OCV drops to 12.6V due to cyclic use, they should be given a "Freshening Charge" at 14.1-14.4V constant voltage with a charging current of less than 19A for 24 hours.
Can I use the Victron charger to achieve this while in the battery bank, or is it best to remove each battery from the bank and charge individually on a separate charger?
Multiplus-IIbattery charging
