Is it possible to connect Multiplus II GX to Cerbo GX and use DVCC setting from Cerbo GX like with non GX Multiplus II?
Thank you in advance.
AFAIK this is not possible. Since your Multiplus II GX already contains a GX.. You cannot connect a second GX in the bus. But why would you want this? Your Multiplus GX already contains the GX hardware.
43 People are following this question.
