suodrazah avatar image
suodrazah asked
VRM Portal ID from Serial Number
I'm not sure re. the structure of these forums, so rather than post my question as another answer I have simply re-asked the same question as this thread. Let me know if this is not the preferred way to revive a topic.
My installer unfortunately failed to retrieve the Portal ID and if I can save a few of hours driving that would be great. I have the S/N.
Pretty boring first ever post, I'll try harder to be more interesting in future!
VRM
Hi @suodrazah,
It may be possible for a VRM admin to discover a VRM Portal ID from a serial number, but not for the end-user.
This is also only possible if the GX device has connected to the internet.
I will reply to this message with one that only you are able to see, and you can reply to that with the serial and I will see if I can find out for you.
suodrazah avatar image suodrazah commented ·
Unfortunately the photo of the S/N they sent is a bit obfuscated. The controller is connected and has the remote portal enabled.
It reads as MQ20S0S:IS9N
However, I managed to get ssh access to another IoT device on this site, setup a tunnel and a little routing to get access to the controller UI and navigate to the VRM Portal ID. Will bring it online shortly.
Appreciate the quick reply nonetheless!
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) ♦♦ suodrazah commented ·
Wow, very smart solution.
