Jmarc avatar image
Jmarc asked
hiding SOC
We have an application with a Li-ion battery using BMS not compatible with Victron products. The system also has a CCGX connected to a Quattro as well as a couple of MPPT. The Sytems has other loads not "Seen" by the Quattro.
The Quattro cannot properly identify the current draw has it only sees partial current. We have a separate display for the battery BMS Showing its calculated SOC. As a result the two numbers constantly diverge causing major confusion to our customers.
Any possibility to hide the Quattro calculated SOC from the CCGX display yet display the Battery Voltage (as seen by the Quattro).
CCGX Color ControlSOCgx device
JohnC avatar image
JohnC answered ·
Hi @Jmarc
Yes, Victron recommend that installers do this to prevent customer confusion. Just untick the Enable Battery Monitor in the General tab of VEConfigure..
1637199231322.pngThen the GX will show this..
Jmarc avatar image
Jmarc answered ·
Thanks John.
CCGX Product Manual
CCGX Product page
