Hi
Need some help.
-Is this correct way to connect this setup?
-can i charge simultaneously with Orion tr smart and solar panels while driving?
- when parking can i charge simultaneously with those two 230v chargers and solar panels?
Hi
Need some help.
Is the webasto a factory fit thermotop or similar? Otherwise I'd connect to leisure battery.
I think you can do away with the mains leisure battery charger. Just use one on the starter battery and let the house charge through the Orion.
Most would put isolators, maybe fuses as well between the panels and MPPT.
You'll need a CEE socket for mains hookup if this is a camper.
Thanks!
Webasto is thermotop and it is factory fit and there will be diesel air heater connected to leisure battery.
"Just use one on the starter battery and let the house charge through the Orion. " I will try this and add more fuses/isolators.
Also need to calculate wire diameters and lengths to get right size fuses.
35 People are following this question.
