hk14 avatar image
hk14 asked
Programmable relay Multiplus IP21
I want the relay to be programmed so it is switched open when the Multiplus is connected to the shore power and switched closed at the moment the shore power is not connected.
I programmed 2 assistants the way they should behave like I described but for some reason the relay won’t switch to closed position when the shore power is off. Isn’t this possible?
Should I use the Com and NO ports or the Com and NC ports?
VEConfigure 3
