limerock avatar image
limerock asked
BMV700 current showing high discharge
This installation is on an electric vehicle. This is the second vehicle built and the first one also had a BMV700 installed.
It has 12 AGM 12 volt batteries arranged in 4 banks of 3 for an output of 48V.
The problems are the voltage reads several volts (around 3 volts) lower than the actual battery voltage, and the current on the monitor read -799A.
The amps will change when I turn on the rest of the system, but it only fluctuates down to about -729 amps.
Battery power goes to an unswitched fuse block, 1 amp fuse to the shunt positive.
Shunt is connected to battery, then out to main contactor.
I am just looking at the system without turning on main contactor.
Battery voltage is 53.8V (read with multimeter), and BMV700 reads 50.6V.
Amps read -799.
BMV Battery Monitoramps
limerock answered ·
The RJ-12 wire was reversed rather than straight through. Apparently, the BMV700 will still get power through the PCB on the shunt when wired backwards.
So, if you don't use the cable that comes with the unit, or you modify it to make it shorter, make sure the cable is a straight cable and not reversed.
Victron BMV battery monitors product page
