cpurchas avatar image
cpurchas asked
Display Victron Smart Lithium cell voltages on CerboGX
Hello All, a couple questions for ya ... I currently have a CerboGX attached to a Multi 12/3000 and a custom lithium bank with an Orion BMS that's Victron compatible. I can see my high / low cell voltages on the Cerbo and I can also turn the Multi on/off from the Cerbo. Today I'm testing two Victron 160Ah batteries connected in parallel using the Victron VE.Bus BMS. I can see the batteries and corresponding cell voltages on the Victron Connect app but the battery doesnt appear on the Cerbo the way the Orion did. I can't seem to find the cell voltages on the Cerbo. The ability to turn on/off the Multi is also disabled. Can someone shed some light on this? Is there a way to display Victron battery cell voltages on the Cerbo and also control the Multi as I did before ?
cerbo gxLithium Battery
Hi @cpurchas,
no good new: there is no way to see cell voltages from SmartLithium in Cerbo GX. The only way to see them is in VictronConnect (via bluetooth).
For switching the Multi on/off from the Cerbo, this is not possible when you run a VE.Bus BMS. See also the Cerbo GX manual.
