How can Connect the Venus OS whit VNC-Viewer?
I Cant Connect
Thank you
I Cant Connect
Thank you
this is not (easily) possible. The VNC server, integrated in Venus, only accepts websocket connections and no direct VNC connections.
You could use a workaround involving a Raspberry Pi. I posted a howto years ago:
HowTo: Disable Hotkeys in Venus Remote Console on LAN - Victron Community (victronenergy.com)
BR
there IS a way
use putty,
setup SSH tunnel
then connect to that tunnel, works like a charm, but still only one connection at a time.
25 People are following this question.
