peternielsen avatar image
peternielsen asked
Setting VebusSetChargeState to Force absorb stops if the BMS set the charge to float and then resets flag
If i set the VebusSetChargeState to 2 e.g Forced Absorbtion then the 2 wire BMS signals to go to Float and when the BMS clears the #3 the charger doesn't go back to Absorption but stays in Float, is that intentionally ? @mvader (Victron Energy) do you know?
/peter
modifications
